Unicode Caption Problem
The followings are my block diagram and its front panel
I have two boolean controls as above.  I would like to change boolean controls' captions with a word that includes unicode characters. I wanted to change first control's caption (bool1)by using its property node. The other control's caption was set by using copy and paste directly. First method could't change caption correctly. But other one is successfull. What is the problem with the first one? I added UseUnicode=true line to the labview ini file. Please help me.
(5,529 Views)
(5,521 Views)
Thanks for your response but I know this document already. But the author hasn't explained how to do that. He has provided a function which is password protected. I can use this function for captions but I need to know the solution to change another control's label which doesn't have caption. For example xy graph's x and y axis label. I can't change graph axis names with that function.
Message Edited by mehmetned on 06-16-2010 05:16 AM
(5,515 Views)
Hi again muks,
Can you help me please ? It is really important. Do you know how to do that?
(5,496 Views)
Isn't there anyone knows how to do that? Please help.
(5,480 Views)
(5,473 Views)
I have seen but it isn't a reason that disable me to do what I wanted. My answer is on http://decibel.ni.com/content/docs/DOC-10153 but the solution is in password protected vi.
(5,459 Views)
