Unflatten from Partial/incomplete JSON File
I don't like using extra packages as it means that every developper needs to install them, so I avoid them where posible.
Also the attached snippet takes a complete JSON string and populates a partial cluster, not a partial string and populate a complete cluster (though I've not isntalled it to see if it would do that).
Message 11 of 12
(1,160 Views)
It'll work in either direction:
VIPM packages make install easy.  I usually include a subdirectory of all required packages in the source-code control of the project, so the developer can easily get going.
Message 12 of 12
(1,158 Views)
