Unexpected error on dynamic vi's
Hi All,
I'm attempting to get around the problem of dynamic vi's not being found when run in a TestStand deployment by using the dynamic vi I want to call as a subvi and getting it to return its location by passing in a flag before then calling it dynamically to run as a daemon. (please see attached image).
Unfortunately when I attempt to run it dynamically I get an error 1000 - just wondering if anyone had any ideas about how I could prevent this from happening (if there is a way).
David Clark
CLA | CTA
Genesee Technologies Ltd
Hampshire, England
(2,946 Views)
It's amazing how often you post something on here then within 5 minutes you find a solution!
Realised that if you make the dynamic VI reentrant then when you open a reference it opens another instance of that VI so you don't get the clash. Still a bit annoying as i'd rather avoid having to have 2 instances in memory, but if that's the solution then I'll have to go with it - it avoids the issue of having to specify a dynamic vi's location for different configurations.
David Clark
CLA | CTA
Hampshire, England
(2,941 Views)
