Understanding producer consumer
Good morning everyone,
it seems to be that i have a real problem to understand queues and notifiers.
adding a timeout to first dequeue helped that the consumer loop was running. but my states are switching.
So i tested in simple version with notifier. And it had the same effect. attached is the vi (2014)
My understanding is following.
If i´m sending a message or enum queue to the case, the structure is switching. Then the buffer is clear and no input is on the case selector. Now it´s going back to default.
According to my simplest example with notifiers, how is it possible to hold states?
Message 11 of 14
(999 Views)
Accepted by topic author DickerMoby
Problem with band-aids -> they lead to more band aids. This one is easy to fix, but it's just another band-aid.
The solution is to fix the architecture. Actually, in the example you put up here, you wouldn't have a problem with no timeout, which is the intended way to use Producer-Consumer.
In the 'fixed' VI I attach, I check for timeout.
GCentral
Message 12 of 14
(997 Views)
Assuming I am understanding your problem, what I typically do is hold the timeout in a shift register.  So when a message is received to start acquiring data, the timeout is set to 50 (per your example).  With a string data type, an empty string will be returned from the Dequeue Element if there was a timeout.  So in the "" (empty string) case, you perform the read.  When commanded to stop, set the timeout to -1 (wait forever).
Message 13 of 14
(990 Views)
Hello everyone,
i´m sorry for the late reply.
Thanks to all for the answers and Solutions. I will try and learn more. For first t seems to be good.
So i can think about my generally program structure.
Message 14 of 14
(969 Views)
