Understanding DVRs - II
It's possible that the compiler allocates the memory for the default version of the thing that the DVR refers to.  IOW, the memory is available all the time.
At runtime, if the DVR is valid, then the real data is used in place.
If the DVR is NOT value, the preallocated empty space is used, so that the code inside the IPE has something to work with.
When it's time to close the IPE, if the DVR is valid, then the MuTex is released.
If the DVR wasn't valid, then the result is simply discarded.
It depends on whether the time to allocate is worth more than the space wasted.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 21 of 22
(728 Views)
Look at this thread for more DVR wierdness.
http://forums.ni.com/t5/LabVIEW/LabVIEW-2015-Buffer-Allocation-Bug/m-p/3300392
cheers
mcduff
Message 22 of 22
(721 Views)
