Uncluster to Take the Value
Please find the attached vi.
I want to take the data byte 0xA1 seperately, to perform some operation.
How shall i seperate this data byte from the cluster of 8 bytes?
-mfp
(3,895 Views)
I am having only lv 8.0 here so not able to view your vi. Did you try "unbundle by name" found inside the cluster palatte?
(3,893 Views)
Okay.
Thanks for the help.
-mfp.
(3,891 Views)
Hi Favas,
so you already used UnbundleByName to get the "Data" portion of the "input cluster", but then you fail to get the single byte from the "Data" cluster?
Oh, come on...
(3,879 Views)
Yea, Exactly.
After that, i need to combine two bytes to form a 16-bit hexadecimal data.
ex:- if byte 1 - 0x12 and byte 2 - 0x34 required output of 0x1234.
Result need to be in hex form itself (not decimal). i tried by using join numbers pallette, but result i am getting is in decimal form.
Please comment on this.
-mfp.
(3,868 Views)
@Favas wrote:
[...] result i am getting is in decimal form.
18183i529E1F16553EAD99Change the display of your indicator to hex.
Jim
(3,860 Views)
