Unbundle limit on ring control StringsAndValues?
Hello all,
I'm attempting to retrieve multiple values from various ring controls and compare them against stored values.  I didn't run into anything until my number of values exceeded 9 items.  I've attached a screenshot showing the structure of what I'm attempting.
  1. Create property node for StringsAndValues
  2. Convert the array to cluster
  3. Unbundle
Is there a way to get more than 9 values out?  I tried by name, but the values all share the same index after 7 (=8).
Thanks in advance...
Chris
(3,791 Views)
Accepted by topic author VisionGumby
Right click on the 'array to cluster' primitive and modify the cluster size to suit your needs.
Is there a reason why you convert it to a cluster? Why not just drag down an array index to the size you want.
Message Edited by Troy K on 04-22-2009 10:35 AM
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(3,776 Views)
Simple enough - thanks Troy.
(3,773 Views)
Welcome...
Better still, run it into a for loop extracting out the values and building an array in one step.
That way it automaticall handles changes to the size of the source.
Message Edited by Troy K on 04-22-2009 10:40 AM
(3,769 Views)
Regarding your question Troy - LabVIEW is not my first language and 'm still coming up to speed on some data types.
I've attached a VI attempting what you're describing and this appears to work.  Is this similar to what you're thinking?
VG
(3,735 Views)
Yep, you have the concept right. LabVIEW makes it even easier then that though.
If you right-click on the input tunnel on the for loop you can turn on or off 'auto-indexing'.
(It changes appearance)
 ring values auto indexed
Message Edited by Troy K on 04-23-2009 09:55 AM
(3,717 Views)
Nice.  Thanks for the assist Troy - I'm going to implement this in a sub VI for my app.
(3,698 Views)
