Unbundle by name - critical bug?
I am experiencing a very critical issue which looks like a bug. I am using the Actor Framework. There is this actor called 'Data Files'. If I open one of its method VIs on my computer, some names are wrong in some unbundle-by-name blocks as shown below.
But if my colleague opens the same VI on his computer, they appear as they are supposed to be. We both use LabVIEW 2018 f2. We made sure it is exactly the same VI. I also tried opening it on another computer. It was fine, too. It is just my computer. I uninstalled LabVIEW and reinstalled it. I still have the same problem. It seems the uninstallation left some footprints. When I was reinstalling it, I input a different company name but when I open LabVIEW, it still shows the old company name.
Also, when I changed the actor's class private data (.ctl) by adding a new control or cluster, sometimes it messed up some names in unbundle-by-name blocks in some of the method VIs. It silently ruined the previously working program without giving me any sign. This is quite scary. If it was a safety-related critical part of the program, it could've been catastrophic. I had to open all the VIs and check every single unbundle-by-name block.
There was a known issue that seems related to what I have seen. Has it not been completely fixed?
https://forums.ni.com/t5/LabVIEW/LabVIEW-botches-unbundle-when-cluster-is-changed/m-p/871947
I am stuck. Has anyone else experienced a similar problem? Should I find a way to completely uninstall LabVIEW and try reinstalling it again?
Thank you.
(3,165 Views)
If you have someone else log in to your PC and use LabVIEW does it have the same issue with this file?
If not, the problem is probably some sort of bad file in your C:\Users\<whoever>\Documents\LabVIEW Data\ or in your "AppData" user folder, which (as far as I know) both don't get deleted or cleared when you uninstall and reinstall LabVIEW.  Or something in the registry under the "current user" category.
If you can check this it would at least narrow it down.
(3,150 Views)
Accepted by topic author Chickentree
To add to this, have you tried clearing your compiled cache (Tools->Advanced->Clear Compiled Object Cache)?
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,118 Views)
There is no other Windows account set up on this laptop and the IT team has to be involved to set it up. I tried uninstalling every single NI software component following the steps described in the thread below and then reinstalled what I need. It didn't help.
https://forums.ni.com/t5/LabVIEW/How-To-Safely-Completely-Remove-LabVIEW-2018/td-p/3811269
That was magical! I don't know the mechanism behind it, but that was exactly what I needed to do.
(3,072 Views)
