Unavailability of NI Modbus.llb for 64-bit LabVIEW 2012
Hi all,
I have a LabVIEW code which are developed with LV2012 32-bit.  NI Modbus.llb is used in that code.  Now, I'm trying to convert those code to LV2012 64-Bit and I can't find NI Modbus.llb available for LV2012 64-bit (under instr.lib folder).  All I can find is NI Modbus is available for 32-bit versions, but not 64-bit versions.  Is there any NI Modbus.llb is available specifically for 64-bit?  Or will it work without any issues, if I use 32-bit NI Modbus.llb in 64-bit?
Ajay.
Ajay MV
(2,885 Views)
If you don't have the Modbus palette, then that's because you did not install it. As far as I know, there is only one version and that should work with either 32-bit or 64-bit since it uses the TCP/IP or VISA functions.
(2,866 Views)
