Unable to retrieve 2D array from database
I'm having trouble with retrieving 2D arrays from my database(MySQL).
I have a number of clusters which all map to their own database table.
Some of these clusters contain 1D arrays and some contain 2D arrays.
Inserting a 1D array into the database is no issue (associated column
is of LONGBLOB type). Retrieving a 1D array from the database is easy
with the 'Database Data to Variant' function. Inserting a 2D array is
as easy as for a 1D array, however I can't seem to retrieve a 2D array
in the same way as for a 1D array. Any tips on how to do this would be
greatly appreciated.
(2,691 Views)
Roy, did you wire a 2D array or cluster of 2D array constant to the Database Variant to Data type input when trying to retrieve a 2D array? What is the error that this function returns? Are you using the database toolkit?
Zvezdana S.
(2,691 Views)
