Unable to replicate frations of seconds when reading a timestamp from a binary file
I use LabVIEW to collect packets of data organized in the following fashion:
cluster containing:
single precision floating point number - dt
timestamp - initial time
2D array of singles - data
Once all data is collected the array of clusters (above) is flattened to a string, and written to a text file.
I am attempting to read this binary data into another program being developed in C#. I have no issues reading everything execpt the timestamp. It is my understanding that LabVIEW stores timestamps as 2 8-byte unsigned intergers. The first interger represents the whole number of seconds since Jan 1, 1904 12:00 AM, and the second represents the fractional portion of the elapsed seconds. However, when I read this information in and convert from binary to decimal the whole number seconds are correct, but the fractional portion is not the same as displayed by LabVIEW.
Example:
Hex stored in binary file representing the timestamp: 00000000CC48115A23CDE80000000000
Time displayed in LabVIEW: 8:51:38.139 8/8/2012
Timestamp converted to an EXTENDED floating point number in labview: 3427275098.139861
Binary timestamp converted to a DECIMAL floating point number in C#: 3427275098.2579973248250806272
Binary timestamp converted to a DATETIME object in C#: 8:51:38.257 8/8/2012
Does anyone know why there is a difference? What causes the difference?
Message 1 of 12
(5,051 Views)
binary file?
How did a text file become a binary file?
What am I missing here?
Message 2 of 12
(5,035 Views)
Poor choice of words by me, I apologize.
It is a text file representing binary data.
Message 3 of 12
(5,032 Views)
So, you are using Variant to Flattened String function to flatten your cluster to a string which is then written to a text file?
When I take a Time Stamp Contant set to 8:51:38.139 8/8/2012 and Variant to Flattened String, I get  0000 0000 CC48 115A 2395 8106 24DD 2F1B
Message 4 of 12
(5,025 Views)
No, I do not use Variant to Flattened String, I use Flatten to String...although they return the same thing so this shouldnt be an issue
Message 5 of 12
(5,014 Views)
Well, that Flattened to String with the time stamp constant you gave us doesn't match what you claim is in your text file.
Message 6 of 12
(5,007 Views)
After some more investigating...
I assume you are using a TimeStamp constant with the values I put in my OP to get the flattened string. It appears that if you use a timestamp constant, as opposed to using the Get Date/Time In Seconds VI, two different flattned strings get created. This is probably a little confusing, so let me explain with an example:
I created a VI (VI-1) that uses Get Date/Time in Seconds to get the current time. This timestamp is then flattened to a string using Flatten to String and written to a text file.
I have a seperate VI (VI-2) that uses a timestamp constant with the time that was captured in the original VI. This timestamp constant is then flattened to a string and written to a file.
Time Captured during VI-1's execution: 10:19:30.671 8/8/2012
Hex in VI-1's text file: 0000 0000 CC48 258D 566F 5000 0000 0000
Hex in VI-2's text file: 0000 0000 CC48 258D 5645 A1CA C083 126E
I'm even more confused then I originally was...
Message 7 of 12
(5,004 Views)
Very interesting.
When I use your original timestamp of 8:51:38.139 8/8/2012 to flatten to a text string I come up with 0000 0000 CC48 115A 2395 8106 24DD 2F1B
and when I take that binary hex string and unflatten, I get back the original timestamp.
And, if I use your binary hext string that was in your text file, 0000 0000 CC48 115A 23CD E800 0000 0000 , I also get back the original timestamp.
I have only used the Time Stamp constant to record as-is to a text file.
I agree with you this is very confusing and unexpected.
Message 8 of 12
(4,998 Views)
@nyc_(is_out_of_here) wrote:
Very interesting.
 So you are saying, regardless of which hex string you use, you get the same timestamp back?
Message 9 of 12
(4,995 Views)
Accepted by topic author CJTilley
http://www.ni.com/white-paper/7900/en
The least significant 64 bits should be interpreted as a 64-bit unsigned integer. It represents the number of 2-64 seconds after the whole seconds specified in the most significant 64-bits. Each tick of this integer represents 0.05421010862427522170... attoseconds.
If you multiply the fractional part of your value (2579973248250806272) by 2-64 then I think you will have the proper timestamp in C.
Message 10 of 12
(4,991 Views)
