Unable to programmatically binding control
Working with LabView 8.5, I can't change the binding source (shared variable) in a indicator control that previously is bound to another shared variable, the error 1522 appears.
See details in files attached.
Thank you in advance, any help would be appreciated.
Manuel.
(3,982 Views)
Sorry, I forget to inform that I am using DSC module.
(3,981 Views)
Accepted by topic author MMCDAT
Hi MMCDAT:
If you are using DSC you must follow the instructions that appear in this link:
http://digital.ni.com/public.nsf/allkb/2E8BAD0EA218A7558625712E0003F044?OpenDocument
The first part is about using DSC module and it's you must follow.
If you want to keep using your method you must initialize the data binding before change the path, so set a data binding to this variable before change the path using the property node.
(3,952 Views)
I'm having the same problem.  I have one VI creating the SV programmatically.  I have another VI binding an indicator to the SV.  In that VI I get the same error.  I'm using the SV Binding.zip example to bind the SV to the indicator.  What am I am doing wrong?
SVcreate.png - creates the SV programmatically
SVassign.png - assigns the SV to an indicator
SVsend.png - sends data to the SV
(3,549 Views)
