Unable to print the report in Labview engine , while the same thing is happening for the normal software function
Hi guys,
       I am using Labview 2011 software. While developing the program i used the standard Print repot.vi . This function is working fine in the software but while i try to run the program on Run time engine  ( i.e as application) the reports are getting generated while the entire program is working well.
(3,176 Views)
Please clarify your message.  In your subject, you say you are unable to print.
But in your message you say is it "working fine in teh software" and also "the reports are getting generated".
(3,169 Views)
Sir,
I am using Print report.vi to print the the report and have installed a pdf generator to save the report ( which has to be printed) in PDF format .The program is working properly and PDF is being generated. But now when i run the application of the same program , everything else is happening but the report is not printing. Plz help.
(3,143 Views)
Sir,
(3,129 Views)
