Unable to pass 2d arrays when linking LabVIEW to Intel FORTRAN DLL
I am trying to link legacy FORTRAN code to LabVIEW 2012 SP1. I am able to pass and retrieve 1D arrays (see TestArrrays FORTRAN code below) using the Call Library Function. I pass N using a Pointer to Value, and the arrays using Array Data Pointer for the format with the minimum size set to N. Works great.
If I try a 2D example such as TestArrays2. I enter 2 for the Y dimension which causes the minimum size option to vanish (as designed). However, when I run the calling VI LabVIEW crashes. I believe the issue is that the array size information is no longer passed correctly.
thanks for any help,
- Troy
      SUBROUTINE TestArrays(lun_log, N, X, Y)
!DEC$ ATTRIBUTES DLLEXPORT, C, REFERENCE :: TestArrays
      IMPLICIT NONE
      INTEGER*4 I, N, lun_log
      REAL*8 X(N), Y(N)
      DO I = 1, N
               Y(I) = X(I)*2.0
      ENDDO
      END  !  SUBROUTINE TestArrays
      SUBROUTINE TestArrays2(lun_log, M, N, X, Y)
!DEC$ ATTRIBUTES DLLEXPORT, C, REFERENCE :: TestArrays2
            IMPLICIT NONE
            INTEGER*4 I, J, M, N, lun_log
            REAL*8 X(N), Y(N,M)
      DO I = 1, N
        DO J = 1,M
                   Y(I,J) = X(I) * J
        ENDDO
      ENDOD
      END  !  SUBROUTINE TestArrays2
(2,518 Views)
You cannot pass variable-sized 2D arrays to a DLL like this, because C (which is the model for passing data to a DLL) doesn't have any way to specify the array dimensions. A 2D array is passed as a large block of memory the same way as a 1D array. Search this forum for "pass 2D array to DLL" for more posts on this topic (you might need to use Google and add site:forums.ni.com since the forum search is unreliable). Consider defining Y in your function as a 1D N*M array, and index it with Y(I*N+M).
(2,501 Views)
