Unable to parse data from JSON String
Hello All,
I am trying to parse the data from a Json string via. thingspeak server.
Read URL: https://api.thingspeak.com/channels/1038537/feeds.json?results=2
However, I keep getting an error or a broken wire issue. The thingspeak server offers two URL's one to read the channel field and other to read feed. I have tried both but didn't get any help.
Since I don't have much experience in building clusters to define data type I used the JSON to Cluster VI to generate the cluster.
Attached is the VI, can someone help me with this.
(3,141 Views)
I recommend installing JSONtext (from JDP Science) package from VIpackage manager and using that instead. The VI Attached works I rewired body output to from JSON VI as well
(3,129 Views)
Accepted by topic author layman93
I took a second look at your problem and found out that your cluster was just defined wrong; you put the array in the channel cluster and didn't define name for cluster inside array and caused the wire to break
(3,105 Views)
Thank you Sebram99,
It works now, yes I figured it out why it was causing the wire to break.
Thank you
(3,084 Views)
