Unable to locate variable
Hello all,
I am attempting to put together an application in which a single host retrieves data from 1+ RT-system(s).  I am using shared variables to communicate across the network.  Because the system may have more than one data acquisition system sending data, I would like to host the SVE on the host computer (running Windows 7).  However, I have been unable to get the library to deploy properly when it is located on the Windows PC - I get error -1950679035, "Unable to locate variable in Shared Variable Engine.  Deployment of this Variable may have failed" when I attempt to read one of the SVs.  The communication works seamlessly when the SVE is located on one of the targets, but I want to get away from this as there is the possibility that the machine hosting the SVE is not present if it is on one of the DAQ devices.  I know that I am probably missing something basic (duh), but does anyone have any thoughts?  I have attached the project (it is very simple).
Cheers, Matt
Message 1 of 8
(4,754 Views)
Sounds similar to something I encountered a while back.  You may have to programatically deploy whatever library the shared variables are in.
23424i7DD7BDBFBB733A68
I used "localhost" as the IP
Tim Elsey
Certified LabVIEW Architect
Message 2 of 8
(4,743 Views)
Thanks Tim.  Unfortunately I get the same error.
Message 3 of 8
(4,732 Views)
Oops.  Just realized that this is LV 2010.  If you are interested in running it and need a different version, let me know.  Here is what my VI looked like after implementing Tim's suggestion.:
23438i4938AFCB066F7364
Message 4 of 8
(4,727 Views)
Is this an executable, or a plain ol' VI?  What I'm getting at is, are you sure the path is right?  (I assume the invoke node would throw an error if it wasn't, but I don't know)
The only other advice I can offer up is to make sure all variables are deployed on every system.
If that's not the problem, there's not much more I can offer up.  I have pretty limited experience with networking and shared variables.
Tim Elsey
Message 5 of 8
(4,716 Views)
Haha...obviously mine is fairly limited also.  So, here is the story: my starting point is quite simple and illustrates my problem clearly.  Pretend that there is not two devices that I am attempting to communicate, but simply (for right now), two VIs in a single project on the same machine for which I am using SVs to communicate between.  Pretty basic right?  This is what is throwing the error.  I can move the SVE to another machine (a cRIO chassis) and all is fine.  The trouble all starts (regardless of config) when I attempt to place the SVE on the Windows machine.  I suspect this might be some kind of firewall issue, but it is unclear to me what might be going on.  Anyway, thanks for the help.
Matt
Message 6 of 8
(4,711 Views)
Turn off the firewall for a minute while you test it.  If that's the problem, turn the firewall back on and find where you put in the exceptions and allow the other computer access.
Tim Elsey
Message 7 of 8
(4,706 Views)
Well, it seems that I have no problem doing this on another computer (although that one is running 2009 rather than 2010) so I suspect this is related to the firewall; however, I am unable to turn off the firewall on this particular computer due to group policy issues (that would be a big no no with our security guys).  I will just have to choose a SVE judiciously I guess.
Message 8 of 8
(4,699 Views)
