Unable to locate the Labview Run-Time Engine
Hi everyone,
I am new in labview, and i have Labview 2021 SP1. However, i am trying to install a software called Ncdio ProXR Relay tester but it gives me the following error:
"Unable to locate the Labview Run-Time Engine
Ncdio ProXR Relay tester requiers a version 2015 (or compatible) Labview Runtime Engine. to correct this problem, please contact the vendor or download the runtime-engine from NI web site."
So what is the possible solution for this problem.
Note: I download the driver library for the hardware i have.
Thank you,
Maen Marji
(1,409 Views)
Have you tried installing that runtime? The supplier of the software should have provide that to you as well, but if not you can do it yourself:
https://www.ni.com/en-nz/support/downloads/software-products/download.labview.html#359548
(1,383 Views)
