Unable to locate labview run time engine-Error message
Hi Everyone,
when I try to exetute the .exe file from my laptop, its showing the error message "Unable to Locate the LabVIEW Run-Time Engine".
I have already installed Labview runtime engine 2011 (latest version for windows7 64-bit from NI website). I have attached the screen shot of the error message. please check the attachment.
Please let me know if you have any solution for the problem.
Thanks In Advance.
Thanks & Regards
saamy
(3,451 Views)
Saamy,
is this application 64bit?
If not, you need the 32bit version of the RTE....
Norbert
Norbert
Expert: Geometry
(3,449 Views)
Hi Norbert,
Thanks for the reply.Its 64bit application only and I installed 64bit RTE only.
(3,446 Views)
2011 SP1 or not?
Norbert
Norbert
Expert: Geometry
(3,440 Views)
Hi
Its working now.I installed SP1 32 bit RTE coz I build .exe using 32BIt application. Now I am not facing any problem.
Thanks a lot for ur help guys 🙂
(3,413 Views)
