Unable to load driver dll 'c:\Program Files\National Instruments\Shared\ NI O...
At times when starting labview the NI-OPC Server fails to communicate to the micrologic and PLC5 PLC's.  Restarting the NI-OPC will fix the problem, but I can not ask the operator to do this.
 Error in NI-OPC:  Unable to load driver dll 'c:\Program Files\National Instruments\Shared\ NI O...
(3,242 Views)
Hi there
if the NI-OPC Server is a Windows service you may want to stop/start the servive on the command line using NET shell:
NET STOP   <service>
NET START <servce>
Run "NET START" to get a list of all running services.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,238 Views)
Were you able to implement the above solution? Does this error occur right as you start the server? And is there an error code associated?
(3,208 Views)
