Unable to insert cluster in to array element
Hi Stephen,
I know I'm late in the discussion and usually I hesitate to cite the LabVIEW help, but as you are complaining about "misleading wording" I took a screenshot of the LabVIEW2009 help on InitArray:
The help article for that function didn't change a lot since then. Could you please mark the "misleading wording" in this article?
The LabVIEW help for basic LabVIEW functions is quite good. That's why I suggest to read the help (when I think it's all said in the help)…
Message 31 of 32
(1,191 Views)
The help is clear. The terminal label could be better in my opinion.
By the way, I wasn't even using that function to begin with. I was told to by someone on here and after I tried the program using the initialise array function I still had the same problem as before. Leading me to believe the problem originated in the code I had originally. Hence why I didn't look too closely at the initialise array function.
Can we all stop acting as though I've committed some horrendous sin and just accept I didn't understand a function.
Labview 14.0, Labview 12.0
CLAD
Mechanical Engineering Student
Message 32 of 32
(1,178 Views)
