Unable to get data from a remote citadel database with READ TRACE.vi
Hello
I can get the trace list with Get TRACE LIST.vi from the remote citadel database. But if I want to receive data from a known trace with READ TRACE.VI the vi finished after 30s with a timeout warning.(HIST_ReadNumericTraceCORE.vi, Query failed to complete within the timeout of 30 seconds.)
I have no idea how to solve this problem.
Can anybody help me?
Georg2
(3,685 Views)
Hi Georg2,
do you´ve already tried to view the traces with Max? Maybe this tutorial might help you to do this http://zone.ni.com/devzone/cda/tut/p/id/2940. Would it be possible for you to post your program?
Greets Philipp N.
Message Edited by Philipp Nörtersheuser on 10-19-2006 03:10 AM
(3,677 Views)
Hello Philipp,
my MAX-version is 4.03. Trying to connect to my remote database in the way the tutorial describes has no success because after chossing the remote computer I can't browse the database path (Failure: Cannot browse for a folder on a remote machine).
However, I tried it with "Citadel 5 Universe"-item in MAX. The connection to the database is correct. But watching a trace with the trace-view function tolds me "no data". But I am absolutely shure that data at the watched trace is available, because I can see them on my application at the remote computer.
Note: If I oppenend the database folder at "Citadel 5 Universe" a yellow call sign appears at the database folder. I don't know what it means.
Do you have any idea?
Best wishes.
Georg2
(3,671 Views)
Hi Georg2,
actually I am programming something that might be comparable to your problem, but I haven´t programmed so much with the DSC functions before, so it could take some time.
By the way I am searching in our database for some comparable problems or interesting forum threats...If you do not know these they might be interesting for you
http://forums.ni.com/ni/board/message?board.id=170&message.id=167306&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=40076&requireLogin=False
Greets Philipp
(3,667 Views)
Hello Philipp
please have a look at the attachment file. There you can see my programmend vi and some screenshots.
This file I have already  send to NI support.
The forum threats I have already known, but they can't help me.
Best wishes
Georg2
(3,664 Views)
Hello
I solved my own problem. If I deactivate XP-Firewall on my desktop-PC (remote pc operates with WIN2000) reading of remote database works fine.
After that I activate my firwall again, but remote reading is still running.
I have no explanation for this, but system is running now.
Thanks for your help
Georg2
(3,652 Views)
