Unable to create an executable in LabVIEW 2010
I have an application written in LV8.2 which turned smoothly.
I passed under LabVIEW 2010, and I get an error when creating an executable.
The error occurred at 1: Node method in
AB_Build.lvclass:Copy_Files.vi->AB_Application.lvc​lass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->​AB_Build.lvclass:Build.vi->AB_Application.lvclass:​Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build​.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyC​aller
Possible reasons:
LabVIEW: An input parameter is invalid. For example, if the input is a path, it may contain a character that is not authorized by the operating system like? or @.
NI-488: Command requires GPIB controller as a controller in charge.
Method Name: Linker: Write To File Info
After some research, I isolated the sub VI that was causing the problem.
It is a. Net that can launch a pdf file
If I put this functionality directly into the main diagram (without a sub VI), I get the following error:
The error occurred at 74: Node method in
Possible reasons:
LabVIEW: Memory or data structure corrupt.
Note: I made a small app that uses only the VI and I do not have PB.
Someone there a line of research?
Thank you in advance
(4,237 Views)
Hello dca,
Thanks for posting on National Instruments forum.
You can find here a post for a similar issue.
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(4,191 Views)
