Unable to convert Variant data to boolean cluster - REST API
Hi everyone,
I am trying to convert variant data to Boolean cluster data using "Variant to data function" but I am getting the error 91.
I could be able to unflatten json string to variant data successfully, if you look into the image attached.
I also tried unbundling the 'SetupState' cluster to 'state'cluster before wiring to variant to data function's type input. But unable to convert the data successfuly.
Please share any inputs. Thank you in advance.
(1,803 Views)
If you flatten to a JSON string you need to unflatten from JSON. Flatten variant creates a much different result.
Qestit Systems
Certified-LabVIEW-Developer
(1,802 Views)
I see no image attached
(1,759 Views)
Sorry, here is the image.
(1,681 Views)
Thanks for the help. I found the issue. The default type input of 'variant to data' is actually a cluster of integer data, but not the cluster of boolean data. Thanks once again.
(1,664 Views)
