Unable to connect with LabVIEW FPGA Compile Cloud Server
I'm trying to compile a LabVIEW FPGA project using NI LabVIEW FPGA Compile Cloud Service, but when I tried to connect I get the following error message,
I followed the instructions listed here, there's onething still confusing to me is that the "User Name" in the instructions says a word but in my case I had to use "Email Id", does this matter?
any suggestions would be much appreciated.
System Info:
OS:           Windows 7 64 Bit
Software : LabVIEW 2014 32 Bit - FPGA Module
Best Regards
Shankar
(4,819 Views)
Hello SankarV
For the User Name you can use your email address, that’s how I connect to the Cloud service.
There are a couple of reasons why you cannot connect to the compile service:
You will also require SSP to use the Cloud Service, if the problem persists, I would recommend using your SSP to get targeted help by creating a service request – either online or by calling your local NI office.
(4,776 Views)
Hello Tom,
Many thanks for your response Smiley Happy
  • I've checked my firewall settings & its seems it's already been disabled.
  • Xilinx IP: I do have Xilinx Compilation tools installed on my pc, does it make any difference?
  • I do not have any experience with PortQry tool, but I have tried as you suggested & this is what I see from the UI
we do have SSP with NI.
Thanks again for your time 🙂
Best Regards
Shankar
(4,767 Views)
Accepted by topic author Shankar*
The issue is now fixed!!
For some reasons my corporate network wasn't allowing me to use this NI Cloud Service, when I changed the network it started working.
Best Regards
Shankar
(4,733 Views)
