Unable to ReInstall LabView after failed installaition
I tried to install LabView 6.1. During the installaition I had problems installing the DAQ drivers. After the failed installation I tried different things but in the end I ended up with reomoving all the files and all the regisrty entries that I could find concerning LabView. I did run the unistall programs first but I still got the follwing problem:
When I try to install LabView now everything works fine, that is, I can select what to intall and so on BUT when the installation program shows what it is going to install it never includes the LabView program. So I can install the runtime engine and so on but not the program. Do you have a cleanup program that I can use to make sure everything from the failed install
ations are completely removed or do you have another solution to the problem?
(2,608 Views)
Problems with installation are best handled with NI's tech support. You can reach them at www.ni.com/ask.
(2,608 Views)
