Ultiboard
Good day,
I have of the following software package.
UTIBOARD 2001
UB2001 Professional-Full Package
S/N: UP-1004-12375-1021-01105
Release code: 1522-6027-5330
I have an old design and when to make an new printout.
The printout possible, for all the components prinout the value that is OK, but I want also an printout whit the refdes.
It possible for me to change that for each component.
I have the following question: is possible to change for all the components in one step from value to refdes.
I it possible can you give my an tip.
Best Regards
L.v.Rijn
RIETEC
rietec@planet.nl
(2,837 Views)
(2,834 Views)
Dear Mr v Rijn,
I was able to select multiple components (only enable the component filter) and change the visible attributes. Select the components; rightclick and chose properties. Under the attributes tab you are able to change the visibility settings of refdes.
Please be aware that I tested this in the latest version; 2001 is a version before NI took over Electronic Work Bench; I don't have acces to the pre NI versions.
Martijn S
NI Netherlands
(2,801 Views)
