10-14-2025 06:47 AM
I am currently using the Dual Channel Spectral Measurement block to perform analysis of a system. One of the goals is to perform the analysis several times and average the results. For that, I have placed the block inside a while loop and turned on the averaging option, but I am still confused if this is the correct approach to achieve my goal.
I would truly appreciated fi someone could provide some additional insights
Solved! Go to Solution.
10-14-2025 09:56 AM
Start with showing your code. Words are insufficient to really tell what you are doing.
10-15-2025 09:43 AM - edited 10-15-2025 09:47 AM
This LabVIEW example does just that (put the dual-channel spectral analysis block in a loop):
<LabVIEW>\examples\Express VIs\Express VI - Dual Channel Spectral Measurement.vi
This example doesn't use Express VIs:
<LabVIEW>\examples\Signal Processing\Waveform Measurements\Frequency Analysis of a Filter Design.vi
These examples each measure the averaged frequency response for a digital filter. If you need to measure the frequency response for a physical system, acquire the reference and response signals in the loop as well.
AND as Altenbach suggests, share your code to get more directed guidance.
