UTF8 database bug
Hello all,
I have found a possible bug in the LV Database toolkit.
For example a query to a database encoded with SQL_ASCII, that works with the toolkit:
SELECT col FROM public.test
However, with a PostgreSQL UTF8 database it has to be modified to:
SELECT "col" FROM public.test
As it is now, I have to add quotes for every column, which leads to fairly "UTF8-specific" database LV classes?
I assume the toolkit is not intended to work this way? Smiley Indifferent
Br,
/Roger
(2,699 Views)
(2,667 Views)
