USRP TX RX example code
I m using the NI USRP 2932. How can I extract the header information at the receiver side in USRP Packet TX RX example code?
(3,217 Views)
referred to the user manual of your device>> Setting Up the Network (Ethernet Only)>> Note.
I found out that the NI-USRP uses User Datagram Protocol (UDP) to broadcast packets.
To parse out information such as header Information, you could use the WinPcap Functions.
Good luck,
Greetings and Regards,
James
(3,146 Views)
