USE of CF 6004 with HP IPAQ 5550
Hello
Could someone tell whether we could use CF-6004 with HP IPAQ 5550 PDA? as it looks that the size of the card is a bit larger to fit in the memory card slot.
thanks
Sam
(3,792 Views)
Hi Sam,
Natively you can not use the CF-6004 with the HP IPAQ 5500, as the IPAQ does not have a Compact Flash (CF) slot. However for the IPAQ 5500 you can buy a CF sleeve, I have seen some on eBay, but you should be able to get a HP IPAQ CF Sleeve from a more reputable location.
I hope this answers your question
Regards
JamesC
NIUK and Ireland
(3,631 Views)
