USB vi
I'm searching a way to use the usb port with labview (5.1). Do you know
where could I find exemples V.I. ? I can't find it on the ni.com website.
Thanks in advance,
BJA
(3,683 Views)
It all depends on the driver for that particular usb unit...In many cases the driver will emulate e.g. a serial port and then you can use the standard serial functions...Otherwise you will need to interface using accompanying dll/activeX drivers if such is provided.
Read also:
http://digital.ni.com/public.nsf/websearch/42B604435E3F9604862565E20043CD30?OpenDocument
(3,683 Views)
I am using LabVIEW 6.1 for Linux together with a few CIN's and libusb (
http://libusb.sourceforge.net ) and it works well.
Stefan
(3,684 Views)
Hi Stefan,
I am interested in using a USB device with labview + libusb library.
I tried to use the DLL import function for test with the usb_init, usb_find_busses and usb_get_busses however got error messages. The structure of usb_bus and usb_device seems to be to complex for labview. Is it necessary to write a CIN for this? Is there any sample code on the web or application examples?
Thanks for your time,
Andreas
(3,515 Views)
