This may be one for the sales guys but I'll post it anyway. I'm considering USB to serial (or GPIB) converters (such as NI's http://sine.ni.com/apps/we/nioc.vp?cid=11383〈=US or Keyspan's http://www.keyspan.com/products/usb/pdaadapter/ ) rather than standard ports/cards.
I know it is not possible (easily at least) to write drivers for USB devices using Labview so I'm interested to know exactly how USB-serial converters work in terms of writing a serial/GPIB driver in Labview.
If I were to use one of these converters to write a serial driver for an instrument, how is the USB port viewed by Labview or, more specifically, VISA. If you drop a 'VISAresource name' control onto a Labview panel, does it pick up the serial instrume
nt connected via the USB-serial converter automatically? Or does the USB-serial converter come with additional driver software of its own to handle this? Can a driver written using one of these converters still be used on standard RS-232ports / GPIBcards?
Basically, can someone explain simply how the Labview to USB comms works when using this USB-serial converter?
Dan
