USB to i2c solutions
I concur with smercurio_fc.  We also originally used the Cal-Bay device and switched to the Aardvark.
Jason
Message 11 of 20
(4,266 Views)
Does any one use USB-to-I2C V2.1 with labview? It is manufactured by i2ctools (www.i2ctools.com), but did not provide the command for labview. Any idea?
Opt_Ottawa
Message 12 of 20
(4,229 Views)
If the device came with a dll file, then you could call the functions in the dll to interface with the device.
See this community post. You would already have the dll file, so you would be interested in steps 10 and later.
Peter Flores
Message 13 of 20
(4,209 Views)
I've not got much experience with I2C, but this is what I've found with a few interfaces over the past couple of years. The 8451s can't work as slaves which was a requirement for my project (too difficult says NI - er, what!). Pity, my company bought four. Should've read the data sheet (thought I did). Tried Cal-Bay but never got them to work properly (well, at all, actually). Then found an I2C interface made by Calibre UK Ltd. No LabVIEW drivers or even a command line but came with a very workable DLL that I thought I could hook into with LabVIEW. Too late, effort was pulled on the project and I never got to try it. Still on my list of things to try before I die. Just my threepennethworth...
Message 14 of 20
(4,201 Views)
We use this solution:
SUB-20 Multi Interface USB Adapter USB-I2C, USB-SPI, USB-GPIO, RS232, RS485, MDIO, Ir, LCD, PWM
They provide LabView compatible .NET cmponent and a lot of vi's here:
http://www.xdimax.net/forum/viewtopic.php?f=2&t=25
Message 15 of 20
(3,739 Views)
This is a very old thread but I was hoping someone knowledgeable could update the information in it.
It's mid-2015.... I want a single USB to I2C host-controller which:
- Is cheap (sadly rules out the usb-8541)
- Will work with the I2C 400 khz fast mode
- Gives reliable results everytime.
- Supports LabView for idiots (me) ie. drivers/examples available to work with.
I see that there is the Aardvark and the Diolan are still out there.
Diolan $90 + shipping
Aardvark $275 + shipping
Dimax Sub-20 $79 + shipping
The Diolan is significantly cheaper than the Aardvark which is significantly cheaper than the NI-USB 8541.  The Dimax sub-20 is a wildcard...
Obviously the controllers are packaged up differently but from a simpletons perspective on programming and reliability what would people recommend and why?
Thanks in advance,
Ibboh
Message 16 of 20
(3,247 Views)
Definitely SUB-20. Not only because of it's price but taking in account a "Supports LabView for idiots (me) ie. drivers/examples available to work with."
They have a full set of VI's drivers and samples, besides they provide a grate support even including writing a simple modules for you (they did it for me).
NI LabVIEW
SUB-20-VI-1.2.zip  1.2 09 Jan 2015   Comprehensive LabVIEW and LV2013+ vi modules pack
SUB-20-VI-1.0.zip  1.0 15 Nov 2013   Comprehensive LabVIEW vi modules pack
Message 17 of 20
(3,235 Views)
Great discussion on USB to I2C solutions.  I'd to throw another one into the mix.  Has anyone used the USB to I2C Breakout board from Mayhew? http://mayhewlabs.com/products/usb-to-i2c-breakout  It uses the Silicon Labs CP2112.  It doesn't have LabVIEW drivers but has a dll and sample C and Visual Basic code. At $14.43 it might be worth putting the time into writing drivers.
Message 18 of 20
(3,176 Views)
Good afternoon!
Please download the archive with the LABVIEW project again.
The link to the SUB-20-LabVIEW-0.1.zip and SUB-20-LabVIEW-0.2.zip archives in the previous message is no longer available.
Message 19 of 20
(2,395 Views)
You can download latest version directly from the web site:
http://www.xdimax.com/sub20/sub20.html#DLD
Message 20 of 20
(2,375 Views)
