USB to SPI
Hello
Can we read USB device using Labview 8. Our application can be better explain with the help of block diagram. Please find the attached Document. In this application , we are using a sensor having SPI interface.Then with the help of National Instruments USB to SPI converter we are interfacing it with the PC.
My question is Can we read the data from the sensor using USB to SPI converter.
Please reply as soon as possible since it is very urgent.
Regards
R
(5,010 Views)
For the above explained application we are using NI USB-8451.
Now for reading the data , should i use VISA vis or DAQmx VIs.
Regards
R
(5,004 Views)
Double Post:
Please see this thread for discussion:
http://forums.ni.com/ni/board/message?board.id=170&message.id=201847
(4,997 Views)
