USB to 422 Converter Woes
If the line is not terminated by something, it isn't recognized as a command.
Thanks for the idea, anyway!
Message 21 of 53
(3,703 Views)
Try manually setting the buffer size using 'VISA Set I/O Buffer Size.vi'. You MUST wire the 'size' input.
Message 22 of 53
(3,635 Views)
Thank you Brian for that vi for the ims...it is a good starting point when one want to write a labview programm to controle the IMS drives without having to use the IMS software.
However, I am having problem with that vi. I have a IMS Mdrive23, old generation. In order to see if I can send command to the Mdrive using Labview, I used your vi and the command "FD" (set to Factory Default"). If everything works perfectly, I should get the following response from the Mdrive: "Copyright 2001-2007 by Intelligent Motion Systems, Inc".
The problem is that I don't get that response all the time, instead I get "FD".
More intringuing is that the proper  response is given alternatively with FD when I run the vi several consecutive times.
Would you have some ideas of what could be wrong?
Initially, I thought that the buffer of the Mdrive was full.
What's really intringuing is that it is alternative : "FD" or "Copyright 2001-2007 by Intelligent Motion Systems, Inc", depending on how many times I run the vi.
I would really appreciate to have some comments on that issue.
Message 23 of 53
(3,525 Views)
The "FD" command is being echoed back from the MDrive, AND it is sending the startup block after it resets.  The VI I sent you may or may not read all data, depending on the timing.  If you increase the time delay inside the read loop, I bet you will get all data.  You will have to increase it quite a bit, or put a manual stop button on it once you see all the data.
Message 24 of 53
(3,515 Views)
Thanks Brian for the quick reply.
Regarding the time in the loop and its meaning: is that time related to the response time of the MDrive for all commands or just for the command "FD" ?
Thanks.
Message 25 of 53
(3,498 Views)
It should just be the "FD" command.  It takes some time, I think about a second.  The other commands should happen much faster than that.
Message 26 of 53
(3,487 Views)
Brian,
I am trying to use an MDrive17Plus with Labview. I am taking a look at ims vi you posted. Which termination character should I be using. It is still not clear to me even after reading the posts.
Any other hints will help.
Message 27 of 53
(3,223 Views)
Sam-
My only real experience with the MDrive and Labview was with the simple VI I posted.  I did my project using an HMI that interfaced to the MDrives.  I did another project with Labview and MicroLynx controllers, but that syntax is different.  You should be able to run the VI I posted without a problem.  The termination character I have setup on the write is a CR/LF.  If you get a popup error, then you will want to turn off automatic error handling.  That VI is not what I would use for a true application, though.
Brian
Message 28 of 53
(3,202 Views)
I am able to write single commands to my MDrive17 now through the USB port. I have a few more questions though.
1. Why am I getting the commands echoed back when reading the buffer? It would be very useful to be able to both write and read.
2. Instead of issuing individual commands, how can I run a script?
Sam
Message 29 of 53
(3,176 Views)
1. There is a command to turn the echo off.
2.  I'm not sure, but assume that you mean to run an on-board program.
As with all devices, especially motion controllers, it is best to become intimately familiar with the device before trying to run it from Labview.
Message 30 of 53
(3,171 Views)
