USB detection - FTDI
I use small part of program to detect connected USB devices with FTDI chip.
VI should detect com port.
This working pretty good on my computer, but problem occurred when I try on some other computer.
Actually, it works on 3 PCs, and on two doesn't work. All PCs use Windows 10, 64 bit, all have LV2018 runtime.
In device manager, windows detect all connected devices, all are properly installed.
Have someone idea how to solve this?
Thanks.
(2,543 Views)
Are You sure that the FTDIXX.dll is placed in the same directory on all machines.
It looks as if the path to the dll is coded only in the CIN.
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
(2,478 Views)
