USB connect disconnect using .net
I am trying to determine when an Android usb device is connected and disconnected. I have seen the library here:  https://forums.ni.com/t5/Example-Code/Windows-Message-Queue-Library/ta-p/3996212 but I may not e able to use the supplied dll.
I have seen the the I would like to use the .net interface to access this functionality as seen here: https://forums.ni.com/t5/UI-Interest-Group-Documents/Programatically-Setting-the-Brightness-on-a-Win.... I have not been able to figure out how to get to wm_devicechange using .net.
Any help would be appreciated.
(3,390 Views)
Have you seen the updated library and example here?:
https://decibel.ni.com/content/docs/DOC-41403
(3,337 Views)
Appears to be a dead link in 2021.
(1,957 Views)
