USB Webcam Configuration
I am using a USB Webcam for image acquisition using IMAQ USB 8.6 under LV 8.6.
The images acquired has a resolution of 640x480pixels (a sort of default value).
The camera image chip is 1600x1200pixels.
How can I control the resolution from my VI?
Also I would need to control the rest of parameters, like exposure, white balance, etc.
I could use IMAQdx 8.6 if it helps.
I have manage to control the camera from Vision Assistant 8.6 but I need to do this from my VI.
Best Regards,
Andrei
(3,271 Views)
Hi Andrei
You can do this one of two ways.
  1. Change the Video Mode in Acquisition Attributes in Measurement and Automation Explorer
  2. Using a IMAQdx property node change the Video Mode under Acquisition Attributes
Joe Daily
may the G be with you ....
(3,224 Views)
