USB Serial Resource not found in LabVIEW
I am having an issue with a USB to serial power supply.  Windows device manager says it is present in the system but LabVIEW doesn't see it.  If I reboot the power supply it will normally fix the issue.  Any ideas why it can't be found in LabVIEW? I have tried refesh but no difference.
Matt
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
Message 1 of 8
(5,663 Views)
I am guessing Windows is shutting off the USB port for "power saving" due to no activity.
Buried deep in your Power Options ---> Advanced Settings make sure USB selective suspend setting is Disabled.
Here is what it looks like in Windows 7
=== Engineer Ambiguously ===
Message 2 of 8
(5,644 Views)
It was set to enabled so I disabled it.  I will see if this fixes the issue.  Thanks for your suggestion!
Matt
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
Message 3 of 8
(5,612 Views)
Also in the device manager check all of the "root hub" power management tabs and uncheck "allow the computer to turn off this device to save power"
Again in Windows 7 it looks like this
Message 4 of 8
(5,604 Views)
Still having issues on PC reboot finding the TDK power supply.  I will contact the manufacturer on Monday.  Maybe a firmware issue?  Thanks for your help.
Matt
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
Message 5 of 8
(5,562 Views)
Read the Manual Matt,
I recall having a similar issue at first while I developed the P-n-P Project style Instrument Driver for that device.  I don't recall exactly what it was but, there is a switch setting on the back that must not be in the factory default position.
"Should be" isn't "Is" -Jay
Message 6 of 8
(5,557 Views)
Jeff,
It is a TDK-Lambda Z+ Series Z20-20 programmable power supply. I chose it because there was a LabVIEW driver available. There are no switches on the back and no configuration that says don't find the serial port on reboot. Good point to modify the comm configuration to see if I can find something that does work reliably. It is a USB connection that maps to a serial port. Maybe I will try my own USB to serial converter.
Matt
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
Message 7 of 8
(5,551 Views)
Ahhhh.  A new version of my old friend.  I have not worked with a Z+ series of that TDK Lambda.  Yes, calling them is a must.   Have a manual and a red pen ready when you call.  And post back.
Message 8 of 8
(5,547 Views)
