USB Joystick
     May i know how to use the values i get from my USB joystick and give out  data(5v) to control the USB NI- 6009 .. Like controlling a robot wirelessly.. When i move the joystick to the left, data can be send into the NI-6009 and hence control the motor...
Message 1 of 8
(4,047 Views)
Have you tried the Acquire Input Data function? You can select the type to be joystick. look on the Connectivity>Input Device Control palette. the outputs of the function include button info, direction info, and axis info.
Message 2 of 8
(4,021 Views)
Yes the acquire input function is most likly the way to go.  I have done several apps where the joystick controls motors using a MS sidewinder via USB and the acquire input functions.  What joystick/controller are you using
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 3 of 8
(4,012 Views)
I'm using the Logic3 STAR FIGHTER joystick.. How am i able to link TCP/IP with joystick? cause i need to send the joystick data to another computer..
Message 4 of 8
(3,995 Views)
See the examples of tcp/ip in the example finder.  Esentially, you need to call acquire input for your joystick, flatten this to some string format the client program can understand and do this in a timmed loop, outside the loop open connection with client tcpip and initialize input. after the loop is done (terminating joystick control is ever), close the port and input conection.
Paul
Paul Falkenstein
Message 5 of 8
(3,978 Views)
     I tried using the acquire input form the joystick already.. This is what my vi looks lik now.. below... but somehow i was unable to get the signal i wanted when the click the buttons on my joystick, or is it that i can only view my results on the client?
Message 6 of 8
(3,951 Views)
Hi Sena Scott,
Any data that you send to the client you should also be able to see on the server.  Are you getting any errors?  I would recommend troubleshooting the server VI before you move on to test the data transfer between the two machines.  How are you determing whether or not you get the signal that you want?
Message 7 of 8
(3,921 Views)
You also need to know that the way you are passing data to the tcp write is not correct. You have an inner while loop and until it stops, no data while be passed out of the while loop. You would want to put the tcp write inside the while loop and to avoid continuous writes, you would want to d a write only when the data changes.
Message 8 of 8
(3,917 Views)
