12-12-2005 12:22 PM
12-13-2005 11:00 AM
12-13-2005 12:00 PM
12-14-2005 08:52 AM
Brooks,
Thank you very much for your support. Although this driver is not supported
by NI engineering Staff, I am sure it will benefit a lot of Vision practioners with
small budget.
THX !
Alipio,
You are really doing a very good job to our Vision Comunity , providing good NI fellows
like Brooks with good informations and feedback about your experience using NI IMAQ
USB driver.
Cheers,
Guilherme
12-14-2005 10:14 AM
01-04-2006 09:05 AM
We just put together a way to easily add support for new OSes for the USB driver. Once you have the NI-IMAQ for USB driver installed (it is recommended to use version 1.1.0 put on the web 1-4-2006), rename the ImaqDirectShowDll.dll located in your system directory (C:\windows\system32\) and replace it with the DLL that is attached. Then run a shipping example (C:\Program Files\National Instruments\LabVIEW x.x\examples\imaq\imaqUSB examples.llb) A popup dialog will appear with a string. Please send a screen shot of the first dialog box to support@ni.com with an email title of IMAQ USB Foreign OS String and what OS you are using.
You can replace the ImaqDirectShowDll.dll with the original to get back the original behavior...within a few days/weeks an updated version of the driver will be available with support for your OS.
We have also recently added the ability to set the resolution of the camera programmatically to a supported video mode of the camera without using a popup dialog box. The driver that has this feature is now available on the web. Upgrading to version 1.1.0 which has this feature should break existing code, but the IMAQ USB Init will have an additional input to allow you to specify which video you want to acquire with.
Hope this helps,
Brad
01-04-2006 11:21 AM
01-13-2006 02:27 AM - edited 01-13-2006 02:27 AM
Message Edited by TonP on 01-13-2006 09:29 AM
01-13-2006 03:28 AM - edited 01-13-2006 03:28 AM
Message Edited by TonP on 01-13-2006 10:33 AM
Message Edited by TonP on 01-13-2006 10:35 AM
01-13-2006 10:01 AM
Here is an updated DLL with support for Norwegian and Dutch...I will update the Example Program soon, but wanted to get as many languages in before I update the web link....make sure you have installed the latest NI-IMAQ USB (version 1.1.0) before replacing the DLL in the windows/system32 directory with this one.
Hope that helps,
Brad
