USB-6251 AO AI
各位好,
我用USB 6251做一个模拟信号生成和采集实验,过程如下:将AO0(PIN15)与AI0(PIN1)相连,AIGND与AOGND相连,在Labview中编程输出偏移为零正弦波(过零点)电压信号,从AI0采集
问题是,为什么我采集到的正弦波信号有偏移,且偏移大小不定,从-0.75V到-2.23V都有?难道AO通道与AI通道存在电势差?
另:将AIGND与AOGND断开也是一样的情况,采集信号的偏移不是零。
(2,927 Views)
Hi everyone,
I did a simulation in USB-6251: connect AO0(PIN15)to AI0(PIN1), and AOGND to AIGND, and then I make a programme in Labview to output sine waveform vlotage (offset voltage=0) to AO0 and acquire it in AI0. the problem is the waveform I acquired from AI0, its offset is not 0, is -1.75V, -2.0V, -2.23V........ I cann't understand that. the waveform I acquired should be the same as I generate, is that right?
thanks
(2,926 Views)
