USB 6211 Encoder
I am using a incremental encoder (1024 Counter Per Revolution) to measure the angular position of the shaft, and generate TTL signal when shaft is at certain degree. I am using USB 6211 DAQ, and LabView. I am using the Analog Input as external clock source with the setting of contiuous sampling at 10,000 Hz Sampling Rate, and 1 Sample to Read (i.e. Buffer size). At low rpm I am getting correct output but at high speed I am getting the error cited below.
Some or all of the samples requested have not yet been acquired.
To wait for the samples to become available use a longer read
timeout or read later in your program. To make the samples
available sooner, increase the sample rate. If your task uses a
start trigger,  make sure that your start trigger is configured
correctly. It is also possible that you configured the task for
external timing, and no clock was supplied. If this is the case,
supply an external clock.
Property: RelativeTo
Corresponding Value: Current Read Position
Property: Offset
Corresponding Value: 0
Task Name: _unnamedTask<55AB>
I wanted to know 1. How to choose buffer size?, and 2. possible cause of the error.
Message 1 of 14
(6,907 Views)
I don't understand. What is the relationship between the encoder and the analog input. Is the encoder output the external clock?
One thing to be careful about is that clock inputs expect VERY clean signals. Overshoot, undershoot, noise, ringing -- they will all kill you. If you can lay your hands on an analog scope, look at the clock and make sure it doesn't degrade at speed.
Mike...
Ps: if all you have is a digital scope you can try using it, but don't be surprised when you can't see the trouble.
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 14
(6,898 Views)
I use analog input as an external clock for continuous sampling via digital counter. I hope that states my problem clearly.
Message 3 of 14
(6,877 Views)
Could you go in to more detail as to how you are generating this external clock?
Message 4 of 14
(6,864 Views)
So the picture below shows how I am adding external clock.
DAQ_Encoder
Message 5 of 14
(6,858 Views)
How are you generating the clock signal itself?
Message 6 of 14
(6,843 Views)
I dont have any clock signal generator attached at all. I thought NI uses the DAQ board clock to generate clock.
Message 7 of 14
(6,839 Views)
I always like to go through the following link to set up an encoder.
http://www.ni.com/getting-started/set-up-hardware/data-acquisition/quadrature-encoders
As far as the error is concerned, this part of the error message seems the most relevant.  From your last post it sounds like you are not supplying an external clock.
Message 8 of 14
(6,792 Views)
I think Matt's link is a good starting point. I'd try using a counter as detailed there.
Message 9 of 14
(6,744 Views)
Hello, I follow the same procedure as outlined in that link and this video (https://www.youtube.com/watch?v=YGRKAxjYDes). So here is the problem in detail. What I am trying to do is to generate a TTL signal whenever the encoder reaches 0,90,180, and 270 degree.
Here is the snapshot of my VI, and what I am trying to do. I can run the VI at Continuous Sampling setting (buffer size of 1, and sampling rate of 12000 Hz) if I am only displaying the angle, but when I want to trigger the camera it gives me the error 200279.
Message 10 of 14
(6,730 Views)
