USB-6210 Analog in, same channel, but two readings orders of magnitude different
LV 2014
Windows 7 Professional
64 bit
NI USB-6210
The vi takes two samples from the 6210 analog in, ch 0.
Front panel picture shows the channel input is the same, but the two readings are 10^5 magnitude difference.
There is a one second time delay between readings and a digital output goes from high to low.
The vi needs refinging admitedly.
vi's attached are saved as 2014 version
and 2013 version, respectively.
(2,959 Views)
Accepted by topic author Carmen92126
Well, That would be because you wrote a bug.
Change that to AI Voltage!
And stop writing bugsSmiley LOL
"Should be" isn't "Is" -Jay
(2,955 Views)
Thank you kindly Jeff!
(2,935 Views)
