USB 6009 thermocouple noise
Hey,
I am doing measurements with a k-type thermocoule and DAQ Usb 6009, considering using the CJC AD595, or other type.
I would love to have the program if you still have it? My email is Ingridmoe87@gmail.com
Thankful for respond;)
Message 11 of 22
(2,317 Views)
Hello to all,
there's a very useful discussion! In the short time I'd get the same problem with T-sensing.
Kenny, I appreciate your suggestion and would like to get a possibility to test your vi.
Could I get the permission to see the post usb6008/9 and to get your vi?
Greetings,
Vitali
Message 12 of 22
(2,291 Views)
Hello Kenny,
I'm intersted in having your program for the AD590 and USB6008.
Can you send it to me at this email : ajmd_@hotmail.com  ?
Thanks in advance,
ALEJANDRO...
Message 13 of 22
(2,249 Views)
Hello Kenny,
I'm really interested in having your program for the AD590 and USB6009
since I am currently facing the same exact problem
I would really appreciate it if u could send it to me at this email: tamimi_11@yahoo.com
If possible any of you guys who received the vi could send it to me
thank you in advance
Sam
Message 14 of 22
(2,226 Views)
Hello Kenny,
I'm really interested in having your program for the AD590 and USB6008
I would really appreciate it if u could send it to me at this email: ajmd_85@hotmail.com
Sam
Message 15 of 22
(2,206 Views)
Hello to all,
I' wondoring if Kenny send anybody last posters his vi or invitation to the closed discussion.
Could anybody else help me to read this topic or send the desired vi?
I'd appreciate your help!
Message 16 of 22
(2,194 Views)
I need help. I want to measure the temperature of an IGBT during the switching,
I want to use 3 thermocouple type K and I have software DAQmx 9.5 and Labview2009, and the hardware are PCIe-6351, SCB-68.
The IGBT works with frequency 10 000Hz, Then the sampling rate that I will want to use should be 1000,000 (1M).
When I connect the thermocouple and start measuring using an example program from Labview I can see so big noise (-20 to +20) although the IGBT is not working.
Could you please advice me, so I can make my experiment.
Thank you,
Tanya
Message 17 of 22
(2,164 Views)
Tanya,
Your question has nothing to do with the USB-6009 although it is otherwise related to the topic of this thread. It might have been better to start a new thread and refer to this one if you have tried things mentioned here.
1. What kind of signal conditioning are you using?  At 150 degrees C a type K thermocouple generates 6.1 mV.  While the devices you are using can, in principle, measure the thermocouples directly, it is likely that you will have some problems. The absolute accuracy is specified as about 10 times larger than the resolution, and that is based on averaging 10000 samples. An isolated preamplifier mounted close to the thermocouple might give better results.
2. The "noise" you are seeing, is the +/- 20 in degrees, LSBs, uV, or some other units? Is it random or periodic (power line frequency)?
3. What style of thermocouple are you using? Is it connected to the case of the IGBT?  What kind of test circuit will you be using?
4. Will the DAQ system be measuring anything else in addition to the temperature?
Lynn
Message 18 of 22
(2,160 Views)
Hi Linn,
Thank you for your quick respond.
I need to measure the case temperature of the IGBT. I will measure Vce   and Ic of the IGBT using an oscilloscope. The first pulse will trigger the measurement of the temperature.
I have not tried yet when the IGBT is working, because when it is not the temperature should me approximately 25 C and the the output shows 5-50 C.
Tanya
Message 19 of 22
(2,156 Views)
Tanya,
From a table of Type K values it appears that you are seeing about 1 mV of noise on a 1 mV signal.
Is this variation random or periodic?
When you see this noise, is the IGBT case grounded or floating?
Lynn
Message 20 of 22
(2,143 Views)
