USB-6009 DAQmx counter task stops and does not restart when VI restarts
I have DAQmx counter task that "hangs up" while troubleshooting a VI and does not restart when I restart theVI.  See attached VI fragment.  The counter works reliably in normal operation but some combination of Pausing and running "highlighted" causes it to cease working.  This is in LabVIEW 2009.
It will restart if I close the VI and reopen it.  However, this causes me to loose my tediously constructed probe window with ten
probes.
Is there some way to re-initialize a DAQmx task without closing the VI?
This is slowing down the troubleshooting considerably.
As an alternative, if someone can suggest a way to preserve a Probe Watch Window after closing the associated VI, that would be a workaround.
(2,498 Views)
Accepted by topic author wildcatherder
Please disregard.
Counter task works - it's the rest of the program that's hung up.
(2,491 Views)
