USB 6008 with Raspberry Pi
Simple question, Can you use standard NI USB DAQ devices such as 6008/6009 with the 2014 Home LV ver.  with VI deployed to a Raspberry Pi as simply as you can if the VI was running on a regular windows PC?
Alan
(5,008 Views)
No. But using the PC as a bridge between the Pi and the 6008 is an option.
edit: hmm, but I have found this: https://decibel.ni.com/content/docs/DOC-25806
It might be possible??? 🙂 Lets wait for some gurus! 🙂
(4,998 Views)
Having not done this, I say it does look possible.  It looks like the LINX toolkit does support using system exec as a way to send commands to the terminal and back, and using that, along with the code you linked to should make it possible.  Great find.
(4,939 Views)
S it looks like the answer is , it can be done. But it is not as easy as just loading the drivers and hooking up a 6008 just like in LV, and it looks like DAQ assist porbably would not work, correct?
Alan
(4,873 Views)
