USB-485 with LabView via B-Con development
Hi support,
   I am running a LabView project developed from B-CON and it is using a legacy RS232 port (COMM1).  It does not work with a USB-485 interface.  What do I need to tell my developer to use the USB-485 interface (half duplex)?  I have other applications (not LabView) that can use either RS232 or USB-485 interfaces.  I presume the programmer needs to do something to tell the interface to switch between transmit and receive or do the drivers do that automatically?
Bruce at Solar.
(3,016 Views)
If you plug-in your USB device you can within the Windows (?) device manager or in MAX see which COM port is attached to this USB-RS485 interface.
A USB-RS485 has an automatic Tx enable / Rx Disable. If your USB device can handle 485 and 422 it is possible that you have to configure it for automatic Tx enable.
Kees
(3,003 Views)
   I figured out that much.  What do I tell my programmer to do differently in LabView between talking to a true RS232 port and a USB-485 simulated COMM Port.  Is there any sample code available or configuration settings in LabView or does LabView need different drivers other than what comes with the USB-485 interface?
Bruce
(3,000 Views)
If you use Windows you should see your USB device within the device manager. You also see there which COM port number the USB-RS485 interface got from Windows.
Your application should able to use and select different COM port.
Kees
(2,995 Views)
