URLs to Tree
I am using the DSC module to get a list of URLs from an OPC server (multiple OPC servers).  The list of URLs can be in the hundereds.  I wrote a program before that took me a while.  I used the envoke node to populate the tree.  It was only capible of displaying 3 layers in.  Now I have to re-do the code.  Is there any easy way to do this?  I attached my old code.  Look at Tree Main.vi in tree structure folder.
This is the formats for 2 differend OPC servers:
ni.var.psp://toshlap/AO2000/OPC1/NI OPC Client Status/Server ProgID
ni.var.psp://toshlap/AO2000/OPC1/Optima1/IO_Card0/AO1/Name
(2,660 Views)
Good Afternoon,
You might be able to use the Tree Control API located here to make recoding this a little easier on yourself.  I hope this helps!
-Cody C
(2,627 Views)
