UPV Audio Analyzer GPIB Problem
I am using LabVIEW8.2 with PXI 8105 controller which has inbuild GPIB Port. I am controlling R&S UPV Audio Analyzer through GPIB interface, using LabVIEW driver VI's provided by R&S(Driver Document tells driver should work for LV 6.1 and Higher). I am trying to read some measurement data from the instrument every 10sec. It is working fine for more than 2-3 hours but randomely stops after giving 'Read Timeout Error'. After that I have to restart the UPV instrument Firmware to make things work again properly.  Please let me know if anyone had simliar kind of problem and any possible workaround to this.
venky
(4,487 Views)
Venky,
Is this the driver that you are referring to?
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=6409
What version of NI-488.2 do you have?
Trey B
Applications Engineering
(4,467 Views)
Yes, This is the driver I am using (Not using LV 8.0 Driver but 7.1 with LV 8.2 Runtime)
NI-488.2 Driver Version is 2.43
Venky
(4,458 Views)
Today tried with LabVIEW 8.0 Driver for UPV with LabVIEW 8.2 Run time, but still no improvement. Instead of VXI driver, writing my own driver with VISA and GPIB commands will improve things?
Venky
(4,455 Views)
Perhaps the problem is caused by the Instrument itself, did you ask the R&S support for some support? Also the driver on the R&S hompage should be identical to the one you can get in the driver-liberary.
http://www2.rohde-schwarz.com/en/products/test_and_measurement/product_categories/audio/audio_produc...
The UPV-Firmware itself:
Are you using the current Firmware 2.1.1.261? If your Firmware should be 1.something call R&S for a update-CD. First Versions were kind of buggy and instable during remote-control operation. (And a lot of measurements are missing also).
 I do not know if writing a own driver using the GPIB commands will help. If you want to try it, there is a function you can use to create a setup:
If you start the "Scipi Recording" situated in the "Sequence"-menu all changes made on the UPV-settings will be recorded with in a editor-window with their command-lines you will need for VISA. But you will have to look up all other commands like "Trigger" or data-readout in the programming manual.
So it is depending how complex your application will be.
Greetings,
Florian
(got UPV number 3 just yesterday :))
(4,437 Views)
HI guys,
 I need to communicate the UPV audio analyzer using GPIb in matlab  or python? I have written code in python
import visa
import time
UPV=visa.instrument("GPIB::20");
UPV.write('*RST');
print UPV.ask('*IDN?')
UPV.write('SOUR:FREQ 1.5 kHz')
UPV.ask('SOUR:FREQ?')......... It was showing error as   VI_ERROR_TMO: Timeout expired before operation completed
can u guys some coding to see how u r communicating with UPV 0-240 khz audio analyzer for analyzer config or generator config
Any help
THanks and regards
dileep
(3,915 Views)
